    SQL Fehler beim Update auf 0.9.9
    19 Posts 5 Posters 6.3k Views 1 Watching
      smeissner
      Hallo Leute,
      habe heute Versucht von version 0.8.3 auf 0.9.9 zu updaten. Leider bekomme ich nur einen weisen Bildschrim mit folgender SQL Meldung:
      isys_exception_database : Query error: 'ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`': Error on rename of './idoit_data/isys_catp_ip_list' to './idoit_data/#sql2-8bc-26c0cb' (errno: 152) Backtrace: #0 _get_backtrace() called at [/var/www/i-doit/src/classes/exceptions/isys_exception_database.class.php:24] #1 isys_exception_database->__construct(Query error: 'ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`': Error on rename of './idoit_data/isys_catp_ip_list' to './idoit_data/#sql2-8bc-26c0cb' (errno: 152), Array ([server] => 5.0.51a-24+lenny2,[host] => Localhost via UNIX socket,[client] => 5.0.51a,[proto] => 10)) called at [/var/www/i-doit/src/classes/components/isys_component_database.class.php:182] #2 isys_component_database->query(ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`) called at [/var/www/i-doit/src/classes/components/isys_component_dao.class.php:253] #3 isys_component_dao->update(ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`) called at [/var/www/i-doit/updates/classes/isys_update.class.php:1003] #4 isys_update->update_database(/var/www/i-doit/updates/versions/v0.9.9/update_data.xml, isys_component_database Object ([] => idoit_data,[] => Resource id #112,[] => isys_component_database_transaction_manager Object ([] => isys_component_database Object ( *RECURSION*,[] => 1),[] => idoit,[] => VtVzvB5zQLW9hNXE,[] => localhost,[] => 3306), 1) called at [/var/www/i-doit/updates/classes/isys_update.class.php:245] #5 isys_update->update(idoit_system, Array ([9] => idoit_data,[10] => idoit_spielemandant)) called at [/var/www/i-doit/updates/update.inc.php:451] #6 include_once(/var/www/i-doit/updates/update.inc.php) called at [/var/www/i-doit/index.php:278] (Extended Information: array ( 'server' => '5.0.51a-24+lenny2', 'host' => 'Localhost via UNIX socket', 'client' => '5.0.51a', 'proto' => 10, ))
      Kann mir da geholfen werden?
      • R
        rgarcia
        Das hört sich ganz so an wie mein Fehler 🙂
        Siehe hier in diesem Thread steht schon einiges dazu: http://www.i-doit.org/forum/index.php/topic,1356.0.html
          smeissner
          hallo,
          leider bringt auch die lösung aus diesem Post nix.
          Ich habe es jetzt mit dem idoit-0.9.9-update-FK-FiX versucht, leider bekomme ich da nach dem Update wieder:
          isys_exception_database : Query error: 'ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`': Error on rename of './idoit_data/isys_catp_ip_list' to './idoit_data/#sql2-8bc-367e93' (errno: 152) Backtrace: #0 _get_backtrace() called at [/var/www/i-doit/src/classes/exceptions/isys_exception_database.class.php:24] #1 isys_exception_database->__construct(Query error: 'ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`': Error on rename of './idoit_data/isys_catp_ip_list' to './idoit_data/#sql2-8bc-367e93' (errno: 152), Array ([server] => 5.0.51a-24+lenny2,[host] => Localhost via UNIX socket,[client] => 5.0.51a,[proto] => 10)) called at [/var/www/i-doit/src/classes/components/isys_component_database.class.php:182] #2 isys_component_database->query(ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`) called at [/var/www/i-doit/src/classes/components/isys_component_dao.class.php:253] #3 isys_component_dao->update(ALTER TABLE `isys_catp_ip_list` DROP FOREIGN KEY `isys_catp_ip_list_ibfk_2`) called at [/var/www/i-doit/updates/classes/isys_update.class.php:1003] #4 isys_update->update_database(/var/www/i-doit/updates/versions/v0.9.9/update_data.xml, isys_component_database Object ([] => idoit_data,[] => Resource id #112,[] => isys_component_database_transaction_manager Object ([] => isys_component_database Object ( *RECURSION*,[] => 1),[] => idoit,[] => VtVzvB5zQLW9hNXE,[] => localhost,[] => 3306), 1) called at [/var/www/i-doit/updates/classes/isys_update.class.php:245] #5 isys_update->update(idoit_system, Array ([9] => idoit_data,[10] => idoit_spielemandant)) called at [/var/www/i-doit/updates/update.inc.php:451] #6 include_once(/var/www/i-doit/updates/update.inc.php) called at [/var/www/i-doit/index.php:278] (Extended Information: array ( 'server' => '5.0.51a-24+lenny2', 'host' => 'Localhost via UNIX socket', 'client' => '5.0.51a', 'proto' => 10, ))
            smeissner
            keine Tips mehr?
            würde den Entwicklerteam auch einen SQL Dump zur Verfügung stellen
            • G
              gr
              führ bitte das hier aus:
              SHOW CREATE TABLE isys_catp_ip_list;
              und schreib das Ergebnis hier.
              Vermutlich heißen in Ihren DB die Foreign keys anderes als in den o.g. Fix.
                smeissner
                Hallo gr,
                ergebniss:
                Table: sys_catp_ip_list
                	CREATE TABLE `isys_catp_ip_list` (
                 `isys_catp_ip_list__id` int(10) unsigned NOT NULL auto_increment,
                 `isys_catp_ip_list__isys_ip_assignment__id` int(10) unsigned default NULL,
                 `isys_catp_ip_list__isys_catp_ip__id` int(10) unsigned NOT NULL default '0',
                 `isys_catp_ip_list__title` varchar(255) collate utf8_unicode_ci default NULL,
                 `isys_catp_ip_list__description` text collate utf8_unicode_ci,
                 `isys_catp_ip_list__status` int(10) unsigned default '1',
                 `isys_catp_ip_list__property` int(10) unsigned default '0',
                 `isys_catp_ip_list__hostname` varchar(255) collate utf8_unicode_ci default NULL,
                 `isys_catp_ip_list__dhcp` int(10) unsigned default '0',
                 `isys_catp_ip_list__address` varchar(255) collate utf8_unicode_ci default NULL,
                 `isys_catp_ip_list__mask` varchar(255) collate utf8_unicode_ci default NULL,
                 `isys_catp_ip_list__primary` int(10) unsigned default NULL,
                 `isys_catp_ip_list__gateway` varchar(255) collate utf8_unicode_ci default NULL,
                 `isys_catp_ip_list__dns_domain` varchar(255) collate utf8_unicode_ci default NULL,
                 `isys_catp_ip_list__dns_server` varchar(255) collate utf8_unicode_ci default NULL,
                 `isys_catp_ip_list__active` int(10) unsigned default NULL,
                 PRIMARY KEY  (`isys_catp_ip_list__id`),
                 KEY `isys_catp_ip_list_FKIndex1` (`isys_catp_ip_list__isys_catp_ip__id`),
                 KEY `isys_catp_ip_list_FKIndex2` (`isys_catp_ip_list__isys_ip_assignment__id`)
                ) ENGINE=InnoDB AUTO_INCREMENT=76 DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci
                • G
                  gr
                  wie ich gedacht habe, in der update-data.xml, heissen die Foreign keys "isys_catp_ip_list_ibfk_1" und "isys_catp_ip_list_ibfk_2".
                  In Ihren DB (???) heissen die aber "isys_catp_ip_list_FKIndex1" und "isys_catp_ip_list_FKIndex2" und Drop-Befehl (löschen) kann nicht ein Feld löschen was nicht vorhanden ist.
                  In idoit-0.9.9-update-FK-FiX-Datei, finde die Datei update-data.xml (liegt hier: idoit-0.9.9-update-FK-FiX\updates\versions\v0.9.9) und in der Datei update-data.xml in der Zeile 1249 und 1251 ersetze die zwei Zeilen:
                  ALTER TABLE  isys_catp_ip_list DROP FOREIGN KEY  isys_catp_ip_list_ibfk_2 ;
                  ALTER TABLE  isys_catp_ip_list DROP FOREIGN KEY  isys_catp_ip_list_ibfk_1 ;
                  mit:
                  ALTER TABLE  isys_catp_ip_list DROP FOREIGN KEY  isys_catp_ip_list_FKIndex1 ;
                  ALTER TABLE  isys_catp_ip_list DROP FOREIGN KEY  isys_catp_ip_list_FKIndex2 ;
                    smeissner
                    hallo gr,
                    werde das dann mal teste. Noch eine Frage dazu: der Auszug oben ist vom Mandanten 1. wir haben aber 2. Muss ich da noch was ändern?
                    • G
                      gr
                      Führe noch mal
                      aus.
                      Und dann prüfe mal wie die key für den 2. Mandant definiert sind:
                      KEY isys_catp_ip_list_FKIndex1 (isys_catp_ip_list__isys_catp_ip__id),
                      KEY isys_catp_ip_list_FKIndex2 (isys_catp_ip_list__isys_ip_assignment__id)
                      also:
                      CREATE TABLE isys_catp_ip_list (
                      isys_catp_ip_list__id int(10) unsigned NOT NULL auto_increment,
                      isys_catp_ip_list__isys_ip_assignment__id int(10) unsigned default NULL,
                      isys_catp_ip_list__isys_catp_ip__id int(10) unsigned NOT NULL default '0',
                      isys_catp_ip_list__title varchar(255) collate utf8_unicode_ci default NULL,
                      isys_catp_ip_list__description text collate utf8_unicode_ci,
                      isys_catp_ip_list__status int(10) unsigned default '1',
                      isys_catp_ip_list__property int(10) unsigned default '0',
                      isys_catp_ip_list__hostname varchar(255) collate utf8_unicode_ci default NULL,
                      isys_catp_ip_list__dhcp int(10) unsigned default '0',
                      isys_catp_ip_list__address varchar(255) collate utf8_unicode_ci default NULL,
                      isys_catp_ip_list__mask varchar(255) collate utf8_unicode_ci default NULL,
                      isys_catp_ip_list__primary int(10) unsigned default NULL,
                      isys_catp_ip_list__gateway varchar(255) collate utf8_unicode_ci default NULL,
                      isys_catp_ip_list__dns_domain varchar(255) collate utf8_unicode_ci default NULL,
                      isys_catp_ip_list__dns_server varchar(255) collate utf8_unicode_ci default NULL,
                      isys_catp_ip_list__active int(10) unsigned default NULL,
                      PRIMARY KEY  (isys_catp_ip_list__id),
                        smeissner
                        hallo gr,
                        ich fasse mal fix zusammen:
                        firmenmandant:
                        spielemandant
                        ) ENGINE=InnoDB AUTO_INCREMENT=55 DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci
                        Was komisch ist: Der Spielemandant hat 302 Tabellen, der Firmenmandant 303
                          Das sind nun Auszüge aus der fehlerhaft geupdateten DB oder von einem 0.9.8-3 backup ?
                            smeissner
                            das ist der Auzug aus der aktuellen datenbank (Versionsstand 0.9.8-3)
                            • P
                              pfranke
                              Hallo an alle.
                              Ich denke ich habe das Problem gelöst bzw. umgangen.
                              Die lösung ist:
                              1. Ein sauberes (leeres) I-doit System (V. 0.9.8-3 ) aufsetzen
                              2. Das alte System (gefüllt) backupen und updaten. –> geht schief
                              3. An der Fehlermeldung die "defekte" tabelle auslesen
                              4. Altes System mit backup zurücksetzen
                              5. Mit php-myadmin die "Problemtabelle" aus dem Sauberen System exportiern (mit Keys)
                              6. Mit php-myadmin die Inserts aus der "Problemtabelle" im gefülten System exportiern
                              7. Die "Problemtabelle" im alten System löschen, mit export aus dem sauberen System wieder erstellen und mit dem export aus dem gefülten System wieder befüllen.
                              8. Die Schritte 1-7 gegebenenfalls wiederholen (bei mir waren ca. acht Tabellen betroffen)
                              Irgendwann konnte das Datenbankupdate durchlaufen.
                              Bei dem Punkt "migration" gab es nochmal Probleme in der Tabelle "isys_cats_lic_group". Er konnte wiedermal die Schlüssel nicht löschen weil das umbenennen fehlschlägt.
                              Der lösungsweg von oben funktionierte hier nicht.
                              Die Tabelle war bei mir relativ klein. Ich hab ich sie einfach lehr geräumt und das Update konnte komplett durchlaufen.
                              Das Problem ist jetzt das ich Datenbankfehler bekomme wenn ich im Webinterface Arbeite.
                              Beim öffnen eines Clients kommt beispielsweise:
                              isys_exception_database : Query error: 'SELECT isys_catg_overview_list__id FROM isys_catg_overview_list WHERE (isys_catg_overview_list__isys_obj__id = '36') LIMIT 1;': Unknown column 'isys_catg_overview_list__isys_obj__id' in 'where clause'
                              Hat jemand ne Idee?
                                ALTER TABLE  isys_catg_overview_list ADD  isys_catg_overview_list__isys_obj__id  isys_catg_overview_list__isys_obj__id INT( 10 ) UNSIGNED NULL DEFAULT NULL;
                                  Du hättest das hier auch probieren können: http://www.i-doit.org/forum/index.php/topic,1457.0.html
                                  • P
                                    pfranke
                                    Danke erstmal.
                                    Ich hab beides gerade Probiert.
                                    Bei meiner etwas beschädigten 0.9.9 bringt das fix garnichts. Es läuft zwar durch behebt aber nicht mein Problem.
                                    bei einer v0.9.8.3 bekomme ich nur ein:
                                    "Fatal error: Call to undefined method isys_component_database::get_database() in /var/www/i-doit/updates/classes/isys_update.class.php  on line 1217"
                                    im Browser geliefert
                                    Der SQL-befehl ist laut mysql syntaktisch falsch.
                                    Ich hab ein wenig probiert und glaube jetzt der sollte so heißen:
                                    ALTER TABLE  `isys_catg_overview_list` ADD  `isys_catg_overview_list__isys_obj__id` INT( 10 ) UNSIGNED NULL DEFAULT NULL;
                                    Der befehl wird akzeptiert und ich bekomme im Webinterface einen neuen Fehler:
                                    isys_exception_database : Query error: 'SELECT * FROM isys_catg_application_list LEFT JOIN isys_connection ON isys_connection__id = isys_catg_application_list__isys_connection__id LEFT JOIN isys_obj ON isys_connection__isys_obj__id = isys_obj__id WHERE TRUE AND (isys_catg_application_list__isys_obj__id = '36') AND (isys_catg_application_list__id = '5')': Unknown column 'isys_catg_application_list__isys_connection__id' in 'on clause'
                                      Dann wurde die Migration bei dir leider nicht richtig durchgeführt. Du musst wohl leider nochmal reverten, den Fehler den du bei der Migration hattest zuerst beheben und dann das Update auf die 0.9.9 ausführen
                                      • P
                                        pfranke
                                        Ich habe noch den DB-Dump aus v 9.8.3.
                                        Der fix v0.9.9-fk-cleanup bringt mir allerdings den "fatal error" aus meinem letzten Post.
                                        Wie behebe ich jetzt die Probleme auf der DB?
                                        es waren vollgende Tabellen betroffen:
                                        Datenbank update
                                        isys_catp_ip_list
                                        isys_catg_nagios_list
                                        isys_dependency
                                        isys_nagios_contacts
                                        isys_file_version
                                        Migration
                                        isys_cats_lic_list
                                        Es ist immer der bekannte fehler bei dem die Keys nicht gelöscht werden können.
                                        • P
                                          pfranke
                                          Hat niemand eine Lösung?
