    Non existent icon file for 'Power distribution unit' object
    Scheduled Pinned Locked Moved Development
    2 Posts 2 Posters 2.8k Views 1 Watching
    • N
      nfpct
      The field
      Administration->Global settings->Object type configuration->Infrastructure->Power distribution unit->"Icon"
      contains the value "pdu.gif".
      This file does not exist. That messes up the layout of Rack (front/back) view.
      I changed the value of the "Icon" field to "images/icons/silk/lightning.png" to fix the problem.
      This bug is present in the pro version.
      • LFischerL
        LFischer
        Hello nfpct,
        the icon "pdu.gif" should be inside the "<i-doit>/images/tree/" directory. Is it possible that the icon is missing in your setup / update package? If so - which version are you currently running?
        Greetings from Düsseldorf</i-doit>
