    Setting static values when importing
    2 Posts 2 Posters 671 Views 1 Watching
    • T
      tlh
      Hello,
      Using i-doit pro 1.8.3.1. Is there a way to set certain static values when importing items via csv? For example, I am importing 30 new routers and want them to have the CMDB status of "ordered" as soon as they are imported.
      Trent
      • bheisigB
        bheisig i-doit Team
        Hello,
        Welcome to our i-doit forums. If you use the CSV data import the only way to set "static values" will be within the CSV file. For example, add another column for the CMDB status and insert the value "ordered" for each object in a row.
        Greetings,
        Benjamin
