    Links with cable-import doesn't work with Power Consumer
    2 Posts 2 Posters 669 Views
      sbaas_keylane
      Oke. How does the linking to other object work? Because linking to Power Consumer doesn't work. Can you help troubleshoot.
      What I done is creating a new switch object. Then created two Power Consumer object with title PSU1 and PSU2. The I checked the documentation for Cabling import module https://kb.i-doit.com/display/en/Cable+patches+and+paths
      For information the power-object is the first object in my CSV and the switch is de last object in my object. So >
      PowerUnit1;Outletxx;CableXX;PSU1;Switch;PSU1
      PowerUnit2;Outletxx;CableXX;PSU2;Switch;PSU2
      Then after importing this was the result.
      • Philipp HörselmannP
        Philipp Hörselmann
        Hey @sbaas_keylane
        based on this picture the connection between PSU1XXXXX03 and Outlet06 is created. In this case I would say, it worked fine.
        If this is not the desired result, I would appreciate you to describe this more detailed.
        Thanks in advance
        Cheers,
        Phil
