Updatecheck does not work with proxy settings
  • if i run updatecheck, i get the following error
    root@i-doit:/var/www/i-doit# ./updatecheck
    • Loading module: updatecheck
      • Checking… Please wait..
        Error while connecting / cURL error: 56 - Received HTTP code 403 from proxy after CONNECT
        Make sure this host is connected to the internet!
        Proxy settings can be configured in src/config.inc.php
        Proxy configuration:  (
          'active' => true,
          'host' => '192.168.XXXXX',
          'port' => '3128',
          'user' => '',
          'pass' => '',
      extract of my config file:
      root@i-doit:/var/www/i-doit/src/config.inc.php
        * @desc Proxy
        *      Proxy configuration
      $g_proxy = array(
              "active" => true,
              "host"  => "192.168.XXXX",
              "port"  => "3128",
              "user"  => "",
              "pass"  => ""
      any suggestions?
  • the update-check script uses METHOD CONNECT.
    this was not allowed in squid.
    in squid.conf i had to put:
    acl PORT_80 port 80            #allow port 80
    http_access allow CONNECT PORT_80
  • In older versions there was also a problem with our curl initialisation, this should be fixed in the most recent version now
Datenschutz / Privacy Policy
