    Crontab problem
    2 Posts 2 Posters 2.6k Views 1 Watching
    • M
      mtsvetkov
      Hi
      I receive the following error when I try to create a new "dataset" from Modules –> i-manageIT --> New (create new dataset)
      VIEW HANDLER:
      Backtrace: #0 _get_backtrace() called at [/usr/local/apache/htdocs/i-doit/src/classes/modules/isys_module_cmdb.class.php:523] #1 isys_module_cmdb->start() called at [/usr/local/apache/htdocs/i-doit/src/classes/modules/isys_module_manager.class.php:268] #2 isys_module_manager->load(2) called at [/usr/local/apache/htdocs/i-doit/src/i-doit.inc.php:125] #3 include_once(/usr/local/apache/htdocs/i-doit/src/i-doit.inc.php) called at [/usr/local/apache/htdocs/i-doit/src/hypergate.inc.php:173] #4 include_once(/usr/local/apache/htdocs/i-doit/src/hypergate.inc.php) called at [/usr/local/apache/htdocs/i-doit/index.php:339]
      isys_exception_jcs : JCS Exception: CRONTAB from $g_jcs[crontab_path] does not exist! Current entry:C:\WINDOWS\SYSTEM32\crontab (Extended Information: 0)
      I am using slack 10. Here is my cron configuration
      */ JOB CONTROL SYSTEM SETTINGS
      Variables for the Job Control System. Please care, that crontab_path is
                writable by the apache user, so the i-doIT Framework can write its
                changes. On Windows, the crontab file MUST be in the system32-directory,
                since the CRON Service can only read from this path. On Unix-systems,
                you should make a soft link from /etc/cron.d/i-doit or whatever your
                cron directory is to webroot/i-doit/cron/crontab. Also make sure, that
                you are allowed to use the crontab command, normally you must write
                your username into /etc/cron.allow /
      $g_jcs = array
      The JCS user must have admin rights to the i-doIT system! /
              "username"              => "",
              "password"              => "",
      Windows systems /
              "crontab_path"  => "C:\WINDOWS\SYSTEM32\crontab",
              "cronwin_path"  => "/usr/local/apache/htdocs/i-doit/cron/crons.exe",
      Unix systems /
              "crontab_path"  => "C:\WINDOWS\SYSTEM32\crontab",            // CRONTAB File path
            "croncmd_path"  => "/usr/bin/crontab",  // CRONTAB Control program
      i-doIT doesn't try to automatically evaluate the process ID of crond,
                enter the path into cronunix_pid /
              "cronunix_pid"  => "/var/run/crond.pid",
              "default"              => array(      "hour"          => 10,
        "minute"        => 30, /10:30/
        "dow"          => 0)  /0=sunday,…,7=saturday/
      Is the cron configuration wrong? or there is another problem?
      Regards,
      Mladen
        Which i-doit version do you have?
        The Task module is deprecated and is replaced with the new workflow implementation in our next version.
