    Fehlermeldung beim Anlegen eines Druckers
    3 Posts 2 Posters 979 Views 1 Watching
    • C Offline
      crispp
      Beim Anlegen eines Druckers erscheint die folgende Fehlermeldung - die Daten sind aber scheinbar korrekt da:
      isys_exception_dao > Running transaction has been canceled. Could not isys_component_dao::update() :
      MySQL-Error: Unknown column 'isys_cats_prt_list__isys_cats_prt_paper__id' in 'field list'
      Query: UPDATE isys_cats_prt_list SET isys_cats_prt_list__description = '', isys_cats_prt_list__isys_cats_prt_type__id = '2', isys_cats_prt_list__isys_cats_prt_emulation__id = '1', isys_cats_prt_list__iscolor = '1', isys_cats_prt_list__isduplex = '0', isys_cats_prt_list__isys_cats_prt_paper__id = NULL, isys_cats_prt_list__status = '2' WHERE isys_cats_prt_list__id = '33';
      Try updating your database. If this error occurs permanently, contact the i-doit team, please. (http://i-doit.org/forum, support@i-doit.org)
      • dsD Offline
        Es scheint als fehlt dir irgendein Update oder deine Grundinstallation war fehlerhaft
        Hier ein Fix für das spezielle Problem:
        DROP TABLE IF EXISTS `isys_cats_prt_list`;
        CREATE TABLE `isys_cats_prt_list` (
          `isys_cats_prt_list__id` int(10) unsigned NOT NULL auto_increment,
          `isys_cats_prt_list__isys_cats_prt_emulation__id` int(10) unsigned NOT NULL default '0',
          `isys_cats_prt_list__isys_cats_prt_type__id` int(10) unsigned NOT NULL default '0',
          `isys_cats_prt_list__isys_cats_prt_paper__id` int(10) unsigned default NULL COMMENT 'Paper format',
          `isys_cats_prt_list__title` varchar(255) collate utf8_unicode_ci default NULL,
          `isys_cats_prt_list__description` text collate utf8_unicode_ci,
          `isys_cats_prt_list__isduplex` int(10) unsigned default NULL,
          `isys_cats_prt_list__iscolor` int(10) unsigned default NULL,
          `isys_cats_prt_list__status` int(10) unsigned default NULL,
          `isys_cats_prt_list__property` int(10) unsigned default NULL,
          PRIMARY KEY  (`isys_cats_prt_list__id`),
          KEY `isys_cats_prt_list_FKIndex1` (`isys_cats_prt_list__isys_cats_prt_type__id`),
          KEY `isys_cats_prt_list_FKIndex2` (`isys_cats_prt_list__isys_cats_prt_emulation__id`),
          KEY `isys_cats_prt_list__isys_cats_prt_type__id` (`isys_cats_prt_list__isys_cats_prt_paper__id`)
        ) ENGINE=InnoDB DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci AUTO_INCREMENT=1 ;
        Auszuführen in der Mandanten-Datenbank (über zB phpMyAdmin)
        • C Offline
          crispp
          Danke für den Hinweis mit dem fehlenden Update. Ich habe nochmals alle Updates installiert - jetzt funktioniert es.
          Christof
