    Help importing from i-doit 0.99
    2 Posts 2 Posters 778 Views 1 Watching
    • 8
      8az__
      Has anyone had experience with importing from an older i-doit version? Can't export csv from the 0.99 version and the new one doesn't handle xml import like it should. Does anyone have any tips?
      • dkirstenD
        dkirsten administrators
        never tried to migrate from such an old version. Since CSV is not available, the only way I could think of would be to use PHPMyAdmin and generate CSV files directly from the database. PHPMyAdmin has an option to export rows from a table as CSV for Excel, so you can clean the data afterwards and then import it into the newer i-doit.
        Viele Grüße,
        Daniel
