"Alert : Could not load global constant cache." problem
I have the following problem:
After successfully installing i-doit with the web installer i click "next" and i get the following error message:Alert : Could not load global constant cache.
Backtrace: #0 _get_backtrace() called at [/usr/local/apache/htdocs/i-doit/src/debug.inc.php:143] #1 isys_debugger_handler_default_alert::execute(Could not load global constant cache.) called at [/usr/local/apache/htdocs/i-doit/src/debug.inc.php:209] #2 isys_debugger::handle(5, Could not load global constant cache.) called at [/usr/local/apache/htdocs/i-doit/src/globals.inc.php:336] #3 include_once(/usr/local/apache/htdocs/i-doit/src/globals.inc.php) called at [/usr/local/apache/htdocs/i-doit/index.php:228]I noticed that this problem is already described in the forum, but in german. Would you please explain it to me in English?
Regards,
Mladen
check if the apache user got write permissions to the following directorys
- temp
- src/themes/default/smarty/templates_c
- src/themes/default/smarty/cache
- src/themes/redbox/smarty/templates_c
- src/themes/redbox/smarty/cache
then open a browser an open the following url
http://i-doit-host/i-doit-path/index.php?IDOIT_DELETE_TEMP
that should work
Thanks.
It works.
