    Connection popup empty
    Scheduled Pinned Locked Moved General
    10 Posts 9 Posters 5.4k Views 1 Watching
    • Y
      ygini
      Hello,
      I'm trying i-doit and I've a problem with the connection popup.
      Most of the software works well. I can connect systems to wire system, connect to cable, etc.
      I've only one problem with the "assigned to connector" feature. When I try to connect some systems together (let say a switch to its pdu) the popup is white and empty. I can't connect to anything.
      Can you explain why? What I should check and fix?
      Best regards,
      Yoann.
      • LFischerL
        LFischer
        Hi Yoann,
        which i-doit version are you using? Just yesterday we released i-doit v1.4.7 - check it out 🙂
        Best regards,
        Leo
        • E
          essb
          I have the same problem I'm on version 1.4.8 with the following settings : on system overviwe its everthing OK.
          Operating System UNIX/Linux, Linux OK
          PHP Version 5.4.4-14+deb7u14 (>5.3.8 recommended) OK
          i-doit Code Version 1.4.8
          i-doit Database Version 1.4.8 Revision 18308
          Database size 25.38 MB
          Browser (client) Mozilla/5.0, Gecko (Firefox/33.0) OK
          how to solve the problem ???
          att, Emerson Souza
          • V
            vvm7ua
            Hi, i have the same problem
            Version: 1.4.8
            • niwrikN
              niwrik
              Hello,
              I have the exact same issue here.  Everything else works flawlessly.  Clean install of 1.4.7 immediately upgraded to 1.4.8 before initial use.  I will be watching the forums for a hotfix/patch.
              Thanks!
              BK
              P.S.  The captcha is very difficult to read! (4th attempt at posting…)
              @ygini:
              Hello,
              Best regards,
              Yoann.
              Have you tried turning it off and on again?
              • P
                Petasch
                same Problem
                • LFischerL
                  LFischer
                  Hello together,
                  as mentioned here we'll have a look at this problem to solve it with the next version once and for all 🙂
                  Best regards,
                  Leo
                  • M
                    matthias_pdm
                    i have the same problem.
                    assigned to connector - the following modal pop up is white and empty …
                    is there any solution for this issue ?
                    Kind Regards
                    Matthias
                    • T
                      tnepus
                      I just started using I-DOIT this week and have the same exact problem as described in this thread. Did it get resolved yet? I should mention, I am trying to connect a switch to a patch panel when I get the blank connection popup.
                      Sincerely,
                      Tim N.
                      • dkirstenD
                        dkirsten administrators
                        Im sorry to say that this will be fixed in the next Open version. We are going to release i-doit Pro 1.8 this month and expect a new i-doit Open Version to be released later this year.
                        Kind regards,
                        Daniel Kirsten
                        Viele Grüße,
                        Daniel
