    Installation help
    Scheduled Pinned Locked Moved General
    4 Posts 3 Posters 1.3k Views 1 Watching
    • T
      takadori
      Hello.
      I just tried to install on DEbian. I got some warnings that I fixed in php and MySQL, and then it complained about wrong MySQL version (5.5). So I upgraded to Recommended 5.7.
      Now when I continue installation I just get a blank screen ? Anyone know what that can be ?
      • creissC
        creiss i-doit Kenner
        Did you fix these errors before or after the installation? The cause for a blank page can be missing rights in the file system. Did you check that? What does your error log say? You can find it under /var/log/apache2/error.log (or similar).
        • T
          takadori
          I fixed them before installation.
          No errors in the log 😞
          I have also ran the permission scripts.
          • dkirstenD
            dkirsten administrators
            Maybe your Webserver does not allow overrides (AllowOverride directive), so that the .htaccess does not work. Or maybe your Apache rewrite module is not loaded.
            Viele Grüße,
            Daniel
